[Bio] / FigWebServices / Emergency.cgi Repository:
Log of /FigWebServices/Emergency.cgi
Links to mgrast_dev_06072011: (view) (download) (annotate)
Thu Apr 2 01:20:45 2009 UTC (11 years ago) by parrello
CVS Tags: HEAD, mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, myrast_rel40, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
Changes since 1.22: +16 -6 lines
Diff to previous 1.22
Added support for alternate tracing keys for command-line tracing.
Mon Jan 19 21:00:27 2009 UTC (11 years, 2 months ago) by parrello
Changes since 1.21: +32 -12 lines
Diff to previous 1.21
Fixed security setting to allow use by next.nmpdr.org. Added support for building from the tracing console.
Tue Sep 9 20:58:27 2008 UTC (11 years, 6 months ago) by parrello
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, rast_2008_0924, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_release_2008_09_29
Diff to previous 1.20
Fixed host pattern to allow more segments.
Wed Sep 3 20:35:48 2008 UTC (11 years, 6 months ago) by parrello
Diff to previous 1.19
Fri May 16 08:34:57 2008 UTC (11 years, 10 months ago) by parrello
CVS Tags: mgrast_rel_2008_0806, rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_08_07
Diff to previous 1.18
Changed from escapeHTML to the safer Clean.
Mon May 5 21:39:32 2008 UTC (11 years, 10 months ago) by parrello
CVS Tags: rast_rel_2008_07_21
Changes since 1.17: +107 -95 lines
Diff to previous 1.17
Made it harder for unauthorized people to invoke the script. The script only works if the referrer is from anno-2 or the current machine.
Thu May 1 07:55:01 2008 UTC (11 years, 11 months ago) by parrello
Changes since 1.16: +3 -6 lines
Diff to previous 1.16
Changed the column count for trace file dumps.
Tue Apr 29 08:07:08 2008 UTC (11 years, 11 months ago) by parrello
Changes since 1.15: +313 -31 lines
Revamped to allow for error log printing.
Wed Mar 19 17:55:38 2008 UTC (12 years ago) by parrello
CVS Tags: rast_rel_2008_04_23
Changes since 1.14: +20 -6 lines
Updated to work with new Wiki.
Wed Feb 27 01:54:08 2008 UTC (12 years, 1 month ago) by parrello
Changes since 1.13: +177 -221 lines
New version designed to work with the wiki from remote machines.
Revision 1.13
Mon Feb 18 07:04:15 2008 UTC (12 years, 1 month ago) by parrello
Changes since 1.12: +0 -0 lines
FILE REMOVED
Removed some obsolete stuff.
Thu Dec 6 14:28:53 2007 UTC (12 years, 3 months ago) by parrello
Thu Jul 26 19:33:16 2007 UTC (12 years, 8 months ago) by parrello
Changes since 1.10: +0 -1 lines
Removed the "uise Sprout" clause so that the program can run on non-Sprout SEEDs.
Mon Jul 16 19:48:25 2007 UTC (12 years, 8 months ago) by parrello
Fixed to escape HTML found inside tracing output.
Sun May 6 10:15:44 2007 UTC (12 years, 10 months ago) by parrello
Changes since 1.8: +7 -1 lines
Upgraded to delete the existing trace file when trascing is activated.
Tue Oct 10 16:04:04 2006 UTC (13 years, 5 months ago) by parrello
Adapted to work better on the bio* machines.
Fri Oct 6 15:40:16 2006 UTC (13 years, 5 months ago) by parrello
Changes since 1.6: +4 -3 lines
Learned a lot about how PERL times work.
Fri Oct 6 00:37:59 2006 UTC (13 years, 5 months ago) by parrello
Changes since 1.5: +5 -3 lines
Fixed a bug in the timing code.
Thu Oct 5 21:51:31 2006 UTC (13 years, 5 months ago) by parrello
Changes since 1.4: +0 -1 lines
Replaced use of DateTime module with Time::Local.
Thu Oct 5 21:17:16 2006 UTC (13 years, 5 months ago) by parrello
Changes since 1.3: +103 -31 lines
Added the ability to display the end of a trace file.
Tue Oct 3 02:33:10 2006 UTC (13 years, 5 months ago) by parrello
Changes since 1.2: +18 -16 lines
Modified to implement the new approach to emergency tracing.
Mon Oct 2 07:14:02 2006 UTC (13 years, 6 months ago) by parrello
Changes since 1.1: +0 -1 lines
Removed obsolete duration display.
Mon Oct 2 03:02:29 2006 UTC (13 years, 6 months ago) by parrello
Implemented a new IP-based file-controlled tracing system that can be activated from the test forms page.
