[Bio] / FigWebServices / DocDirectory.cgi Repository:
Log of /FigWebServices/DocDirectory.cgi
Links to mgrast_rel_2008_1110: (view) (download) (annotate)
Revision 1.7 - (view) (download) (annotate) - [selected]
Fri Jul 28 02:07:28 2006 UTC (13 years, 10 months ago) by parrello
Changed to use the new PageBuilder call signature.
Mon Dec 5 19:12:11 2005 UTC (14 years, 5 months ago) by olson
add license words
Wed Oct 12 21:03:16 2005 UTC (14 years, 7 months ago) by overbeek
CVS Tags: caBIG-00-00-00
Tue Aug 16 21:15:28 2005 UTC (14 years, 9 months ago) by parrello
Converted "htm" web pages to "html" pages.
Tue Aug 16 20:29:10 2005 UTC (14 years, 9 months ago) by parrello
Changes since 1.2: +7 -2 lines
Fixed some documentation.
Mon Aug 1 16:29:22 2005 UTC (14 years, 9 months ago) by olson
Changes since 1.1: +12 -3 lines
Replace use of $FIG_Config::cgi_url with &FIG::cgi_url()
Tue Jul 26 20:20:44 2005 UTC (14 years, 10 months ago) by parrello
Diff to selected 1.7
Added CGI script for documentation directory, replacing the old PHP page.
