[Bio] / FigWebServices / Attributes.cgi Repository:
Log of /FigWebServices/Attributes.cgi
Links to rast_rel_2008_06_16: (view) (download) (annotate)
Tue Apr 29 07:59:22 2008 UTC (11 years, 9 months ago) by parrello
CVS Tags: mgrast_rel_2008_0806, rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21
Changes since 1.12: +2 -2 lines
Fixed. Deprecated ScriptSetup methods are no longer exported by Tracer.
Thu Dec 6 14:23:37 2007 UTC (12 years, 2 months ago) by parrello
CVS Tags: rast_rel_2008_04_23
Changes since 1.11: +15 -15 lines
Tue Feb 20 00:49:01 2007 UTC (13 years ago) by parrello
Changes since 1.10: +2 -0 lines
Fixed a glitch in the POD documentation.
Sun Feb 18 22:14:11 2007 UTC (13 years ago) by parrello
Changes since 1.9: +3 -16 lines
Added tracing.
Sun Feb 18 21:23:01 2007 UTC (13 years ago) by parrello
Changes since 1.8: +239 -55 lines
Changed upload to use standard tab-delimited attribute files instead of two-column tables. Added ability to prefix an object type to the object IDs.
Fri Feb 9 23:55:46 2007 UTC (13 years ago) by parrello
Changes since 1.7: +0 -1 lines
Fixed a bug in the group delete.
Fri Feb 9 22:56:07 2007 UTC (13 years ago) by parrello
Changes since 1.6: +22 -2 lines
Added support for logging.
Tue Feb 6 16:26:52 2007 UTC (13 years ago) by parrello
Changes since 1.5: +144 -72 lines
Added a name field for login purposes.
Fri Dec 15 03:23:23 2006 UTC (13 years, 2 months ago) by parrello
Changes since 1.4: +2 -1 lines
Converted to use new attribute system.
Tue Nov 28 00:55:50 2006 UTC (13 years, 2 months ago) by parrello
Changes since 1.3: +343 -86 lines
Retooled for the new attributes. Object types are gone, and have been replaced by groups.
Wed Nov 15 11:56:38 2006 UTC (13 years, 3 months ago) by parrello
Changes since 1.2: +64 -0 lines
Added the ability to display attribute values.
Thu Nov 9 21:17:52 2006 UTC (13 years, 3 months ago) by parrello
Changes since 1.1: +7 -6 lines
Updated method signatures. The method signatures for the attribute system were changed to reflect more clearly the difference between manipulating keys and manipulating values.
Fri Nov 3 00:24:22 2006 UTC (13 years, 3 months ago) by parrello
Added to allow uploading attribute data.
