[Bio] / FigWebServices / AttribXMLRPC.cgi Repository:
Log of /FigWebServices/AttribXMLRPC.cgi
Links to rast_rel_2011_0928: (view) (download) (annotate)
Fri May 11 06:07:59 2007 UTC (12 years, 11 months ago) by parrello
Changes since 1.8: +1 -0 lines
Added support for the new method to get attribute descriptions by group.
Fri Apr 27 22:15:52 2007 UTC (12 years, 11 months ago) by parrello
Added support for new QueryAttributes feature.
Thu Jan 25 02:40:50 2007 UTC (13 years, 2 months ago) by parrello
Changes since 1.6: +1 -0 lines
Removed support for full-text attribute search.
Thu Nov 16 22:45:43 2006 UTC (13 years, 4 months ago) by parrello
Added GetAttributeKeys.
Wed Nov 15 11:57:18 2006 UTC (13 years, 4 months ago) by parrello
Added support for the EraseAttribute method.
Fri Nov 10 20:18:22 2006 UTC (13 years, 4 months ago) by olson
Changes since 1.3: +5 -1 lines
Only coerce scalars that match the perldata(1) regexp that show them to look like floats. Otherwise
XML-unsafe string constructs don't get properly quoted.
Fri Nov 10 19:31:56 2006 UTC (13 years, 4 months ago) by parrello
Changes since 1.2: +4 -4 lines
Changed to use the new CA interface methods.
Fri Nov 10 19:27:23 2006 UTC (13 years, 4 months ago) by olson
Changes since 1.1: +23 -9 lines
Coerce all scalar data to strings so that genome identifiers don't end up
being transferred as floating point numbers.
Fri Nov 3 22:33:01 2006 UTC (13 years, 5 months ago) by olson
XMLRPC interface for the attribute server code.
