[Bio] / FigWebPages / pir.html Repository:
Log of /FigWebPages/pir.html
Fri Apr 8 20:43:32 2005 UTC (14 years, 10 months ago) by redwards
CVS Tags: HEAD, Root-bobdev_news, caBIG-00-00-00, caBIG-05Apr06-00, caBIG-13Feb06-00, merge-bobdev_news-1, merge-bobdev_news-2, merge-bodev_news-3, merge-trunktag-bobdev_news-1, merge-trunktag-bobdev_news-2, merge-trunktag-bodev_news-3, myrast_33, rast_2008_0924, rast_rel_2008_04_23, rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912, rast_release_2008_09_29
Changes since 1.5: +14 -0 lines
Added creation of the download file from pir.cgi
Thu Apr 7 19:16:10 2005 UTC (14 years, 10 months ago) by redwards
Changes since 1.4: +3 -1 lines
many changes to key/value pairs to make them work
Wed Apr 6 22:40:40 2005 UTC (14 years, 10 months ago) by redwards
Changes since 1.3: +1 -46 lines
adding help functions all over the place
Sun Apr 3 20:42:24 2005 UTC (14 years, 10 months ago) by redwards
Changes since 1.2: +93 -1 lines
changes to pir interactions
Sun Apr 3 19:11:11 2005 UTC (14 years, 10 months ago) by redwards
Added a script to load pir superfamilies in the background. This will download all the data and install it. Changed pir.cgi to background this job as it takes a while.
Sun Apr 3 02:15:15 2005 UTC (14 years, 10 months ago) by redwards
Diff to selected 1.2
changes to pir-seed interactions and new help page
