[Bio] / FigWebPages / ask_CG04.fasta Repository:
Log of /FigWebPages/ask_CG04.fasta
Thu May 14 14:53:09 2009 UTC (10 years, 5 months ago) by dsouza
CVS Tags: HEAD, myrast_33, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
Supplementary material for Evolutionary Cohesion Group Analysis of Aspartokinase paper with Roy Jensen
