[Bio] / FigWebPages / SproutTest.html Repository:
Log of /FigWebPages/SproutTest.html
Sun Oct 8 03:22:50 2006 UTC (13 years, 3 months ago) by parrello
CVS Tags: HEAD, myrast_33, rast_2008_0924, rast_rel_2008_04_23, rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912, rast_release_2008_09_29
Changes since 1.18: +3 -3 lines
Diff to previous 1.18
Made the frames adjustable.
Thu Oct 5 04:03:42 2006 UTC (13 years, 3 months ago) by parrello
Diff to previous 1.17
Added links to the NMPDR development blog.
Wed Oct 4 15:59:40 2006 UTC (13 years, 3 months ago) by parrello
Diff to previous 1.16
Changed to use tracing help instead of the obsolete DFD as the start page for the main frame.
Fri Jul 28 02:46:43 2006 UTC (13 years, 6 months ago) by parrello
Fri Jul 28 02:37:42 2006 UTC (13 years, 6 months ago) by parrello
Converted to new template style.
Sat Jan 7 04:03:49 2006 UTC (14 years ago) by parrello
Sat Jan 7 03:13:07 2006 UTC (14 years ago) by parrello
Converted the script test form so the left panel is generated by a script.
Fri Jan 6 20:52:56 2006 UTC (14 years ago) by parrello
Changed so title shows whether or not Sprout support is present.
Wed Dec 7 19:38:22 2005 UTC (14 years, 1 month ago) by golsen
Don't mean to be pedantic, but I figured that I might as well add newlines
at the end of text files that lack one.  Identified with a script:
/bin/sh -O extglob -c 'for f in */*.@(c|css|html|js|pl|pm|py|TXT); do perl -e '"'"'while(<>) {$s = ! /\n$/} exit $s'"'"' $f || echo $f; done'
fixed with a script:
/bin/sh
for file in _list_; do echo "" >> $file; done
Thu Sep 15 14:34:53 2005 UTC (14 years, 4 months ago) by parrello
CVS Tags: caBIG-00-00-00
Enhanced to allow specification of a different documentation set.
Tue Aug 16 20:27:46 2005 UTC (14 years, 5 months ago) by parrello
Changes since 1.8: +9 -118 lines
Redesigned the Sprout test forms to make the documentation display more robust and to jettison the complicated and only marginally useful method test page.
Wed Jul 27 19:56:16 2005 UTC (14 years, 6 months ago) by parrello
Changes since 1.7: +3 -3 lines
Changed Sprout test page to access the correct documentation files.
Tue Apr 5 05:20:05 2005 UTC (14 years, 9 months ago) by parrello
Changes since 1.6: +12 -12 lines
Fri Feb 25 18:39:45 2005 UTC (14 years, 11 months ago) by parrello
Changes since 1.5: +14 -49 lines
no message
Mon Feb 7 00:30:38 2005 UTC (14 years, 11 months ago) by parrello
Changes since 1.4: +16 -9 lines
no message
Tue Jan 25 01:02:48 2005 UTC (15 years ago) by parrello
no message
Mon Jan 24 07:07:21 2005 UTC (15 years ago) by parrello
no message
Sun Jan 23 22:32:15 2005 UTC (15 years ago) by parrello
Changes since 1.1: +51 -71 lines
no message
Fri Jan 21 15:57:14 2005 UTC (15 years ago) by parrello
no message
