[Bio] / FigWebPages / ERDB_DBD.xsd Repository:
Log of /FigWebPages/ERDB_DBD.xsd
Links to rast_rel_2014_0729: (view) (download) (annotate)
Tue Mar 26 02:08:06 2013 UTC (6 years, 9 months ago) by parrello
Changes since 1.5: +5 -3 lines
Added new fields for KBase support.
Wed Aug 8 14:54:56 2012 UTC (7 years, 5 months ago) by parrello
Changes since 1.4: +14 -4 lines
Fixed to support FulltextIndex elements.
Tue Aug 7 22:50:51 2012 UTC (7 years, 5 months ago) by parrello
Changes since 1.3: +24 -0 lines
Added support for FulltextIndex stuff.
Thu Oct 20 20:38:04 2011 UTC (8 years, 3 months ago) by parrello
Added "embedded" attribute to relationships for 1M embedding.
Tue Oct 11 18:32:16 2011 UTC (8 years, 3 months ago) by parrello
Created XSD for the ERDB database definitions.
Mon Oct 10 20:38:28 2011 UTC (8 years, 3 months ago) by parrello
Moved from Sprout.
