[Bio] / FigWebPages / Attributes_tmpl.html Repository:
Log of /FigWebPages/Attributes_tmpl.html
Sun May 6 09:57:23 2007 UTC (12 years, 5 months ago) by parrello
CVS Tags: HEAD, myrast_33, rast_2008_0924, rast_rel_2008_04_23, rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912, rast_release_2008_09_29
Fixed a bad style sheet link.
Tue Feb 20 00:50:40 2007 UTC (12 years, 7 months ago) by parrello
Changes since 1.5: +4 -3 lines
Added a link to the documentation for the attribute.cgi page.
Fri Feb 9 22:55:01 2007 UTC (12 years, 8 months ago) by parrello
Shifted the group form so that it is part of the main form. This allows both functions access to the user name.
Sat Dec 2 09:40:27 2006 UTC (12 years, 10 months ago) by parrello
Changes since 1.3: +6 -0 lines
Added links to the documentation.
Tue Nov 28 00:54:55 2006 UTC (12 years, 10 months ago) by parrello
Changes since 1.2: +8 -2 lines
Changed positions of some elements so they make more sense.
Wed Nov 15 11:54:04 2006 UTC (12 years, 11 months ago) by parrello
Changed the style for improved appearance.
Fri Nov 3 17:02:36 2006 UTC (12 years, 11 months ago) by parrello
Added for use as a template on the attribute page.
