[Bio] / FigWebPages / Attributes.html Repository:
Log of /FigWebPages/Attributes.html
Links to merge-trunktag-bodev_news-3: (view) (download) (as text) (annotate)
Tue Jul 12 14:34:15 2005 UTC (14 years, 7 months ago) by redwards
Changes since 1.3: +222 -22 lines
Changing attributes and modifying protein.cgi with show/hides
Sat Mar 12 20:30:39 2005 UTC (14 years, 11 months ago) by redwards
Changes since 1.2: +23 -7 lines
Changed Subsystems to allow selection of active_subsetR (rows) based on tag/value pairs
Fri Mar 4 18:38:12 2005 UTC (14 years, 11 months ago) by redwards
Tweaks to attribute editing to the protein.cgi page
Fri Mar 4 06:22:10 2005 UTC (14 years, 11 months ago) by redwards
Big updates to FIG.pm for the addition of methods to properly handle attributes. Also modified genome_statistics to take advantage of these new methods. load_attributes will load genomes and other attributes but doesn't not yet use the new methods (but should), and Attributes.html is some docs.
