[Bio] / FigWebPages / Attributes.html Repository:
Log of /FigWebPages/Attributes.html
Links to rast_rel_2011_0119: (view) (download) (as text) (annotate)
Tue Jun 13 23:32:15 2006 UTC (13 years, 9 months ago) by overbeek
CVS Tags: HEAD, myrast_33, rast_2008_0924, rast_rel_2008_04_23, rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912, rast_release_2008_09_29
Changes since 1.7: +9 -9 lines
RAE: moving PIRSF to links
Revision 1.7 - (view) (download) (as text) (annotate) - [selected]
Sat Oct 22 17:43:49 2005 UTC (14 years, 5 months ago) by overbeek
CVS Tags: caBIG-00-00-00, caBIG-05Apr06-00, caBIG-13Feb06-00
Changes since 1.6: +23 -6 lines
changing the format of attribute_keys
Tue Jul 19 04:54:22 2005 UTC (14 years, 8 months ago) by redwards
Changes since 1.5: +17 -1 lines
Updating attributes code in seed
Mon Jul 18 03:12:11 2005 UTC (14 years, 8 months ago) by redwards
Changes since 1.4: +49 -15 lines
Tue Jul 12 14:34:15 2005 UTC (14 years, 8 months ago) by redwards
Changes since 1.3: +222 -22 lines
Changing attributes and modifying protein.cgi with show/hides
Sat Mar 12 20:30:39 2005 UTC (15 years ago) by redwards
Changes since 1.2: +23 -7 lines
Changed Subsystems to allow selection of active_subsetR (rows) based on tag/value pairs
Fri Mar 4 18:38:12 2005 UTC (15 years, 1 month ago) by redwards
Tweaks to attribute editing to the protein.cgi page
Fri Mar 4 06:22:10 2005 UTC (15 years, 1 month ago) by redwards
Diff to selected 1.7
Big updates to FIG.pm for the addition of methods to properly handle attributes. Also modified genome_statistics to take advantage of these new methods. load_attributes will load genomes and other attributes but doesn't not yet use the new methods (but should), and Attributes.html is some docs.
