[Bio] / FigTutorial / seq_utils.pl Repository:
Log of /FigTutorial/seq_utils.pl
Thu Jun 10 13:39:16 2004 UTC (15 years, 7 months ago) by olson
CVS Tags: HEAD, Root-bobdev_news, caBIG-00-00-00, caBIG-05Apr06-00, caBIG-13Feb06-00, merge-bobdev_news-1, merge-bobdev_news-2, merge-bodev_news-3, merge-trunktag-bobdev_news-1, merge-trunktag-bobdev_news-2, merge-trunktag-bodev_news-3, myrast_33, rast_2008_0924, rast_rel_2008_04_23, rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912, rast_release_2008_09_29
clean up tutorial code
Fri May 21 18:07:06 2004 UTC (15 years, 8 months ago) by olson
Changes since 1.1: +26 -39 lines
Remove tool_hdr-generated stuff.
Remove ^M's.
Fri May 21 17:53:22 2004 UTC (15 years, 8 months ago) by olson
new makefile and first set of tutorial examples
