[Bio] / FigTutorial / evidence_codes.html Repository:
Log of /FigTutorial/evidence_codes.html
Tue Nov 21 19:59:55 2006 UTC (13 years, 2 months ago) by parrello
CVS Tags: HEAD, myrast_33, rast_2008_0924, rast_rel_2008_04_23, rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912, rast_release_2008_09_29
Fixed a spelling error: "disambuating" to "disambiguating".
Tue Nov 21 19:57:24 2006 UTC (13 years, 2 months ago) by parrello
Fixed a typo "cwn" -> "cwh".
Sun Nov 19 13:35:25 2006 UTC (13 years, 2 months ago) by overbeek
Changes since 1.4: +33 -10 lines
update custom evidence codes
Mon Aug 1 22:10:08 2005 UTC (14 years, 5 months ago) by overbeek
CVS Tags: caBIG-00-00-00, caBIG-05Apr06-00, caBIG-13Feb06-00
update evidence code writeup
Mon Aug 1 22:02:23 2005 UTC (14 years, 5 months ago) by overbeek
Changes since 1.2: +18 -1 lines
Wed Jul 27 16:55:16 2005 UTC (14 years, 6 months ago) by overbeek
details on supporting evidence codes
Wed Jul 27 15:46:25 2005 UTC (14 years, 6 months ago) by overbeek
add evidence codes to protein.cgi
