[Bio] / FigTutorial / evidence_codes.html Repository:
Log of /FigTutorial/evidence_codes.html
Links to caBIG-00-00-00: (view) (download) (as text) (annotate)
Mon Aug 1 22:10:08 2005 UTC (14 years, 4 months ago) by overbeek
CVS Tags: caBIG-00-00-00, caBIG-05Apr06-00, caBIG-13Feb06-00
update evidence code writeup
Mon Aug 1 22:02:23 2005 UTC (14 years, 4 months ago) by overbeek
Changes since 1.2: +18 -1 lines
Wed Jul 27 16:55:16 2005 UTC (14 years, 4 months ago) by overbeek
details on supporting evidence codes
Wed Jul 27 15:46:25 2005 UTC (14 years, 4 months ago) by overbeek
add evidence codes to protein.cgi
