[Bio] / FigTutorial / bioinf_first_classes.html Repository:
Log of /FigTutorial/bioinf_first_classes.html
Thu Aug 11 21:00:16 2005 UTC (14 years, 5 months ago) by overbeek
CVS Tags: HEAD, caBIG-00-00-00, caBIG-05Apr06-00, caBIG-13Feb06-00, myrast_33, rast_2008_0924, rast_rel_2008_04_23, rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912, rast_release_2008_09_29
Changes since 1.3: +2 -1 lines
course description
Sun Aug 7 22:06:58 2005 UTC (14 years, 5 months ago) by overbeek
Changes since 1.2: +8 -1 lines
fix to multi-functional roles
Thu Aug 4 16:20:36 2005 UTC (14 years, 5 months ago) by overbeek
Changes since 1.1: +12 -9 lines
add position statement on 2-course sequence
Wed Aug 3 18:09:51 2005 UTC (14 years, 5 months ago) by overbeek
add the 2-course proposal to Tutorials
