[Bio] / FigTutorial / annotation_clearinghouse.html Repository:
Log of /FigTutorial/annotation_clearinghouse.html
Tue Oct 30 20:20:51 2007 UTC (12 years ago) by overbeek
CVS Tags: HEAD, myrast_33, rast_2008_0924, rast_rel_2008_04_23, rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912, rast_release_2008_09_29
Changes since 1.3: +35 -49 lines
update the to ACH writeup
Tue Oct 23 20:59:21 2007 UTC (12 years, 1 month ago) by overbeek
expand tabs in example
Mon Sep 24 22:01:21 2007 UTC (12 years, 2 months ago) by overbeek
Changes since 1.1: +9 -9 lines
update the 1KG update
Mon Sep 24 20:53:51 2007 UTC (12 years, 2 months ago) by overbeek
add a routine in FIG.pm giving who set the function of a peg
