[Bio] / FigTutorial / about_HOPSS.html Repository:
Log of /FigTutorial/about_HOPSS.html
Wed Dec 7 19:38:22 2005 UTC (14 years, 1 month ago) by golsen
CVS Tags: HEAD, caBIG-05Apr06-00, caBIG-13Feb06-00, myrast_33, rast_2008_0924, rast_rel_2008_04_23, rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912, rast_release_2008_09_29
Don't mean to be pedantic, but I figured that I might as well add newlines
at the end of text files that lack one.  Identified with a script:
/bin/sh -O extglob -c 'for f in */*.@(c|css|html|js|pl|pm|py|TXT); do perl -e '"'"'while(<>) {$s = ! /\n$/} exit $s'"'"' $f || echo $f; done'
fixed with a script:
/bin/sh
for file in _list_; do echo "" >> $file; done
Fri Sep 30 20:14:42 2005 UTC (14 years, 4 months ago) by overbeek
CVS Tags: caBIG-00-00-00
Changes since 1.1: +1 -71 lines
fixes to HOPS
Sat Sep 24 14:25:13 2005 UTC (14 years, 4 months ago) by overbeek
the HOPSS stuff for the prototype web site
