[Bio] / FigTutorial / SEED_administration_issues.html Repository:
Log of /FigTutorial/SEED_administration_issues.html
Wed Jul 19 17:36:16 2006 UTC (13 years, 6 months ago) by overbeek
CVS Tags: HEAD, myrast_33, rast_2008_0924, rast_rel_2008_04_23, rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912, rast_release_2008_09_29
Changes since 1.17: +2 -23 lines
Diff to previous 1.17 , to selected 1.16
minor fix to SEED admin document
Tue Apr 26 15:08:26 2005 UTC (14 years, 9 months ago) by overbeek
CVS Tags: Root-bobdev_news, caBIG-00-00-00, caBIG-05Apr06-00, caBIG-13Feb06-00, merge-bobdev_news-1, merge-bobdev_news-2, merge-bodev_news-3, merge-trunktag-bobdev_news-1, merge-trunktag-bobdev_news-2, merge-trunktag-bodev_news-3
Changes since 1.16: +72 -2 lines
Diff to previous 1.16
document importing external protein sequences
Revision 1.16 - (view) (download) (as text) (annotate) - [selected]
Tue Jan 25 23:01:46 2005 UTC (15 years ago) by overbeek
Changes since 1.15: +3 -0 lines
minor correction to computing similarities
Tue Jan 25 22:57:46 2005 UTC (15 years ago) by overbeek
Changes since 1.14: +23 -43 lines
Diff to previous 1.14 , to selected 1.16
update how to compute similarities
Mon Nov 8 19:13:58 2004 UTC (15 years, 2 months ago) by overbeek
Diff to previous 1.13 , to selected 1.16
minor typos in tutorial
Wed Aug 18 22:34:01 2004 UTC (15 years, 5 months ago) by gdpusch
Changes since 1.12: +78 -0 lines
Diff to previous 1.12 , to selected 1.16
Added section on performing automated annotations.
Thu Aug 5 23:26:06 2004 UTC (15 years, 5 months ago) by overbeek
Changes since 1.11: +54 -3 lines
Diff to previous 1.11 , to selected 1.16
fix links in CGI hdr file
Fri Jul 30 22:01:21 2004 UTC (15 years, 5 months ago) by gdpusch
Changes since 1.10: +24 -0 lines
Diff to previous 1.10 , to selected 1.16
Modified "Multiple copies of the SEED" section.
Fri Jul 30 20:48:52 2004 UTC (15 years, 5 months ago) by gdpusch
Changes since 1.9: +15 -2 lines
Diff to previous 1.9 , to selected 1.16
Fri Jul 30 19:21:08 2004 UTC (15 years, 5 months ago) by gdpusch
Changes since 1.8: +29 -17 lines
Diff to previous 1.8 , to selected 1.16
Modified "Multiply copies of the SEED" section.
Wed Jul 28 22:42:21 2004 UTC (15 years, 6 months ago) by gdpusch
Changes since 1.7: +51 -10 lines
Diff to previous 1.7 , to selected 1.16
Added anchors and internal hyperlinks.
Wed Jul 28 21:21:59 2004 UTC (15 years, 6 months ago) by overbeek
Changes since 1.6: +100 -22 lines
Diff to previous 1.6 , to selected 1.16
changes to SEED administration document
Fri Jul 23 20:33:37 2004 UTC (15 years, 6 months ago) by gdpusch
Changes since 1.5: +53 -51 lines
Diff to previous 1.5 , to selected 1.16
Mods to "Adding a New Genome" section
Wed Jul 21 20:25:42 2004 UTC (15 years, 6 months ago) by overbeek
Changes since 1.4: +6 -6 lines
Diff to previous 1.4 , to selected 1.16
mods to SEED administration guide
Wed Jul 21 16:59:51 2004 UTC (15 years, 6 months ago) by overbeek
Changes since 1.3: +55 -9 lines
Diff to previous 1.3 , to selected 1.16
worked a bit on the SEED administration guide
Mon Jun 28 19:21:24 2004 UTC (15 years, 7 months ago) by olson
Diff to previous 1.2 , to selected 1.16
Minor changes
Mon Jun 28 18:31:55 2004 UTC (15 years, 7 months ago) by olson
Changes since 1.1: +69 -16 lines
Diff to previous 1.1 , to selected 1.16
initial fixes
Mon Jun 28 18:08:27 2004 UTC (15 years, 7 months ago) by olson
Diff to selected 1.16
Added new tutorial (copied from seed wiki)
