[Bio] / FigTutorial / 1KG_update.html Repository:
Log of /FigTutorial/1KG_update.html
Thu Sep 27 15:23:44 2007 UTC (12 years, 3 months ago) by overbeek
CVS Tags: HEAD, myrast_33, rast_2008_0924, rast_rel_2008_04_23, rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912, rast_release_2008_09_29
Changes since 1.3: +38 -6 lines
fixes to the 1K update
Mon Sep 24 22:04:36 2007 UTC (12 years, 4 months ago) by overbeek
update 1KG update
Mon Sep 24 22:01:21 2007 UTC (12 years, 4 months ago) by overbeek
Changes since 1.1: +40 -50 lines
update the 1KG update
Mon Sep 24 20:53:51 2007 UTC (12 years, 4 months ago) by overbeek
add a routine in FIG.pm giving who set the function of a peg
