[Bio] / FigKernelScripts / verify_genome_directory.pl Repository:
Log of /FigKernelScripts/verify_genome_directory.pl
Mon Feb 7 18:49:34 2011 UTC (9 years ago) by gdpusch
CVS Tags: mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, myrast_rel40, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
Changes since 1.41: +1 -1 lines
Diff to previous 1.41
Added recognition of "contig.properties" file.
Fri Jan 21 20:44:11 2011 UTC (9 years ago) by redwards
Changes since 1.40: +7 -0 lines
Diff to previous 1.40
checking for taxon id
Wed Jul 28 16:04:27 2010 UTC (9 years, 6 months ago) by gdpusch
CVS Tags: rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119
Changes since 1.39: +74 -57 lines
Diff to previous 1.39
Made script more robust; suppressed some tests for "special_pegs" entires.
Thu Apr 16 17:56:08 2009 UTC (10 years, 10 months ago) by gdpusch
CVS Tags: rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526
Changes since 1.38: +7 -5 lines
Diff to previous 1.38
Replaced all instances of `cat $file` and `head -1 $file` with &FIG::file_read($file) and &FIG::file_head($file, 1), respcectively.
Mon Dec 8 21:23:18 2008 UTC (11 years, 2 months ago) by gdpusch
CVS Tags: rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26
Changes since 1.37: +36 -33 lines
Diff to previous 1.37
Hacks to make RNA-content checker non-fatal and less persnickety.
Tue Dec 2 12:46:18 2008 UTC (11 years, 2 months ago) by gdpusch
Changes since 1.36: +26 -11 lines
Diff to previous 1.36
Allowed validity of AA-amibig "J", and corrected display of invalid AA-chars. Removed support for ambiguous "could-be-STOPs".
Fri Sep 5 21:54:01 2008 UTC (11 years, 5 months ago) by gdpusch
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, rast_2008_0924, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_release_2008_09_29
Changes since 1.35: +100 -0 lines
Diff to previous 1.35
Augmented genetic code table to translate ambiguous codons that _could_ be STOPs as being valid STOPs. -- /gdp
Wed Aug 6 17:53:33 2008 UTC (11 years, 6 months ago) by gdpusch
CVS Tags: mgrast_rel_2008_0806, rast_rel_2008_08_07
Changes since 1.34: +30 -13 lines
Diff to previous 1.34
Hack adding switch to suppress fatality of non-STOP terminated PEGs. Proper rewrite under development.
Wed Mar 12 21:06:13 2008 UTC (11 years, 11 months ago) by olson
CVS Tags: rast_rel_2008_04_23, rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21
Diff to previous 1.33
Don't consider contigs.btree when looking for contigs.
Wed Dec 19 03:09:01 2007 UTC (12 years, 2 months ago) by gdpusch
Changes since 1.32: +4 -2 lines
Diff to previous 1.32
Modified to accept lower-case "x" in a protein sequence. -- /gdp
Wed Oct 10 20:44:18 2007 UTC (12 years, 4 months ago) by gdpusch
Changes since 1.31: +1 -1 lines
Diff to previous 1.31
Fixed obsolete reference to $_. -- /gdp
Fri May 25 22:36:16 2007 UTC (12 years, 8 months ago) by gdpusch
Changes since 1.30: +1 -1 lines
Diff to previous 1.30
Suprress announcement of genetic code unless VERBOSE is set. -- /gdp
Fri May 25 19:00:23 2007 UTC (12 years, 8 months ago) by gdpusch
Changes since 1.29: +152 -214 lines
Diff to previous 1.29
Added alternate genetic code support. -- /gdp
Fri May 25 17:03:29 2007 UTC (12 years, 8 months ago) by gdpusch
Diff to previous 1.28
Modified to reflect changes in BLAST DB names. -- /gdp
Wed Mar 22 22:36:07 2006 UTC (13 years, 11 months ago) by overbeek
Changes since 1.27: +7 -0 lines
Diff to previous 1.27
Added check for untranslated PEGs. -- /gdp
Tue Mar 21 15:53:30 2006 UTC (13 years, 11 months ago) by overbeek
Diff to previous 1.26
fixes to split_and_trim
Mon Dec 5 18:56:38 2005 UTC (14 years, 2 months ago) by olson
Changes since 1.25: +17 -0 lines
Diff to previous 1.25
Tue Nov 22 14:57:50 2005 UTC (14 years, 3 months ago) by overbeek
Changes since 1.24: +1 -1 lines
Diff to previous 1.24
fixes to characterization of hypos
Sun Oct 2 14:52:49 2005 UTC (14 years, 4 months ago) by overbeek
Diff to previous 1.23
Minor change in diagnostic statement. -- gdp
Fri Sep 30 19:23:52 2005 UTC (14 years, 4 months ago) by efrank
Changes since 1.22: +5 -1 lines
Diff to previous 1.22
	    # the DB_File below changes an 11' run into 19', so i've upped the
	                # threshold to 20GB to turn this off for now until a better
				    # fix is done (read tbls first and hash it rather than contigs)
Fri Sep 30 17:35:01 2005 UTC (14 years, 4 months ago) by overbeek
Changes since 1.21: +23 -0 lines
Diff to previous 1.21
Total up contig size, and if >2G, tie %seqs_of to a DB_File hash.
Tue Sep 13 13:34:50 2005 UTC (14 years, 5 months ago) by overbeek
Changes since 1.20: +25 -9 lines
Diff to previous 1.20
fixes to computing starts
Wed Aug 31 21:12:59 2005 UTC (14 years, 5 months ago) by overbeek
Changes since 1.19: +62 -22 lines
Diff to previous 1.19
Added checks for Taxon-ID and sequence content. -- /gdp
Thu Jul 14 21:32:48 2005 UTC (14 years, 7 months ago) by olson
Changes since 1.18: +53 -0 lines
Diff to previous 1.18
Add some checks on assignments file.
Wed Jun 15 15:40:13 2005 UTC (14 years, 8 months ago) by overbeek
Changes since 1.17: +4 -0 lines
Diff to previous 1.17
Added diagnosits for bad STOPs. (Need to add "truncated PEG" logic.) -- /gdp
Wed Mar 30 05:20:14 2005 UTC (14 years, 10 months ago) by overbeek
Changes since 1.16: +6 -5 lines
Diff to previous 1.16
Added printout of record-number to diagnostic msgs. -- /gdp
Thu Mar 17 20:00:37 2005 UTC (14 years, 11 months ago) by overbeek
Changes since 1.15: +70 -2 lines
fixes to extract_genomes
Fri Mar 11 16:18:58 2005 UTC (14 years, 11 months ago) by overbeek
Changes since 1.14: +79 -44 lines
Added checks for dupicated FIDs. -- /gdp
Tue Jan 25 19:24:39 2005 UTC (15 years ago) by overbeek
Changes since 1.13: +6 -1 lines
Fixed bug that script falsely exits with an "O.K." condition when GENOME, PROJECT or TAXONOMY files are missing. -- /gdp
Thu Nov 4 19:47:24 2004 UTC (15 years, 3 months ago) by overbeek
Changes since 1.12: +18 -4 lines
add some files to extracted Global
Sun Oct 24 17:36:02 2004 UTC (15 years, 3 months ago) by overbeek
Allow Data directory as input to build_nr_sources
Wed Oct 20 16:04:15 2004 UTC (15 years, 4 months ago) by overbeek
Fixed wart locating 'contigs' files. -- /gdp
Fri Oct 1 19:48:37 2004 UTC (15 years, 4 months ago) by overbeek
minor fixes to exporting sets
Mon Aug 23 15:22:22 2004 UTC (15 years, 6 months ago) by overbeek
Changes since 1.8: +37 -28 lines
Added check for bad chars in contigs; made output more informative. -- /gdp
Mon Aug 2 21:50:54 2004 UTC (15 years, 6 months ago) by gdpusch
Changes since 1.7: +32 -25 lines
Fixed bug in RNA section; minor cosmetic changes.
Mon Aug 2 15:05:53 2004 UTC (15 years, 6 months ago) by gdpusch
Changes since 1.6: +19 -11 lines
Modified code so that error go to STDOUT and warnings go to STDERR
Sun Jul 18 22:21:10 2004 UTC (15 years, 7 months ago) by gdpusch
Changes since 1.5: +20 -3 lines
Added heuristic check for duplicate contig sequences.
Fri Jul 16 16:28:58 2004 UTC (15 years, 7 months ago) by gdpusch
Changes since 1.4: +9 -1 lines
Added check for duplicate contig-IDs.
Tue Jun 29 18:59:17 2004 UTC (15 years, 7 months ago) by gdpusch
Changes since 1.3: +33 -15 lines
Added code to check PEG fasta files for invalid chars.
Mon Jun 21 20:05:45 2004 UTC (15 years, 8 months ago) by gdpusch
Changes since 1.2: +9 -6 lines
Added numerous checks of genome directory-structure
Tue Jun 8 16:36:04 2004 UTC (15 years, 8 months ago) by gdpusch
Changes since 1.1: +216 -11 lines
Added numerous consistency checks
Mon Dec 1 20:46:40 2003 UTC (16 years, 2 months ago) by efrank
Makefile:
All the rest:
