[Bio] / FigKernelScripts / validate_subsystem.pl Repository:
Log of /FigKernelScripts/validate_subsystem.pl
Mon Dec 5 18:56:38 2005 UTC (14 years, 4 months ago) by olson
Fri Apr 29 22:01:29 2005 UTC (14 years, 11 months ago) by olson
Basic subsystem package validator. Uses SubsystemFile from P2Pupdate module.
