[Bio] / FigKernelScripts / validate_genome_gff.pl Repository:
Log of /FigKernelScripts/validate_genome_gff.pl
Mon Dec 5 18:56:38 2005 UTC (14 years, 2 months ago) by olson
Fri Sep 23 18:52:50 2005 UTC (14 years, 5 months ago) by olson
Changes since 1.4: +6 -1 lines
Don't join the contigs.
Tue May 10 16:29:57 2005 UTC (14 years, 9 months ago) by olson
Changes since 1.3: +22 -4 lines
fix.
Fri Apr 29 20:49:04 2005 UTC (14 years, 9 months ago) by olson
Changes since 1.2: +25 -8 lines
Fix up validation.
Thu Apr 21 16:32:29 2005 UTC (14 years, 10 months ago) by olson
Changes since 1.1: +11 -1 lines
Return nonzero exit code if validation failed.
Thu Apr 21 16:27:17 2005 UTC (14 years, 10 months ago) by olson
Add genome gff validator.
