[Bio] / FigKernelScripts / update_taxonomies.pl Repository:
Log of /FigKernelScripts/update_taxonomies.pl
Fri Jan 13 20:59:56 2017 UTC (2 years, 10 months ago) by olson
CVS Tags: HEAD
Changes since 1.8: +129 -61 lines
Revamp of this script to use efetch utility instead of parsing webpage and to
take a list of genome IDs to update in the current seed, along with an optional
file of taxonomy overrides.
Wed Oct 25 21:03:45 2006 UTC (13 years ago) by overbeek
CVS Tags: mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_rel_2008_0625, mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, myrast_rel40, rast_2008_0924, rast_rel_2008_04_23, rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912, rast_release_2008_09_29
set longer gap between accessing NCBI
Mon Dec 5 18:56:38 2005 UTC (13 years, 11 months ago) by olson
Thu Mar 18 23:18:31 2004 UTC (15 years, 8 months ago) by overbeek
Changes since 1.5: +4 -8 lines
Converted from "wget" to "curl"
Wed Jan 28 16:52:33 2004 UTC (15 years, 9 months ago) by overbeek
make update_taxonomies process genomes in order
Wed Jan 28 16:48:12 2004 UTC (15 years, 9 months ago) by overbeek
make update_taxonomies a bit less upsetting to NCBI
Wed Jan 28 16:42:17 2004 UTC (15 years, 9 months ago) by overbeek
Changes since 1.2: +14 -2 lines
Wed Jan 28 16:31:07 2004 UTC (15 years, 9 months ago) by overbeek
chmod taxonomies on update_taxonomies
Mon Dec 1 20:46:40 2003 UTC (15 years, 11 months ago) by efrank
Makefile:
All the rest:
