[Bio] / FigKernelScripts / update_sims.pl Repository:
Log of /FigKernelScripts/update_sims.pl
Mon Dec 5 18:56:38 2005 UTC (14 years, 4 months ago) by olson
Changes since 1.12: +17 -0 lines
Wed Oct 5 20:34:02 2005 UTC (14 years, 6 months ago) by overbeek
Changes since 1.11: +27 -0 lines
fixes to update_uniq_id_data
Tue Aug 3 21:59:25 2004 UTC (15 years, 8 months ago) by overbeek
CVS Tags: Root-bobdev_news, efrank-preMakefileToStandardMk, merge-bobdev_news-1, merge-bobdev_news-2, merge-bodev_news-3, merge-trunktag-bobdev_news-1, merge-trunktag-bobdev_news-2, merge-trunktag-bodev_news-3
only copy new sim files on update_sims
Tue Aug 3 14:19:05 2004 UTC (15 years, 8 months ago) by overbeek
Changes since 1.9: +5 -3 lines
changes to update_sims to reduce flips
Tue Jun 29 23:59:55 2004 UTC (15 years, 9 months ago) by overbeek
Changes since 1.8: +63 -101 lines
fixes to updating similarities
Sat May 29 16:16:29 2004 UTC (15 years, 10 months ago) by overbeek
fix update_sims
Wed Mar 17 15:37:06 2004 UTC (16 years ago) by overbeek
sims stuff
Sun Mar 14 03:46:16 2004 UTC (16 years ago) by overbeek
Changes since 1.5: +16 -5 lines
fixes
Fri Mar 12 22:59:27 2004 UTC (16 years ago) by gdpusch
Piped merged output sims through reduce_sims. -- /ross
Fri Mar 5 22:22:44 2004 UTC (16 years, 1 month ago) by overbeek
Changes since 1.3: +3 -3 lines
attempt to stop clipping sims
Tue Dec 30 21:42:10 2003 UTC (16 years, 3 months ago) by overbeek
fix bug causing sims to be lost
Sun Dec 21 01:20:59 2003 UTC (16 years, 3 months ago) by overbeek
Changes since 1.1: +16 -9 lines
allow multiple sims files in update_sims
Mon Dec 1 20:46:40 2003 UTC (16 years, 4 months ago) by efrank
Makefile:
All the rest:
