[Bio] / FigKernelScripts / update_nr_cycle.pl Repository:
Log of /FigKernelScripts/update_nr_cycle.pl
Thu Jan 26 13:40:11 2006 UTC (13 years, 9 months ago) by overbeek
load ext org table on update_nr_cycle
Thu Jan 26 03:41:32 2006 UTC (13 years, 9 months ago) by overbeek
Changes since 1.4: +3 -3 lines
allow changes/deletes in nr without cleanup
Thu Jan 26 03:36:47 2006 UTC (13 years, 9 months ago) by overbeek
Changes since 1.3: +3 -2 lines
add check_anno.cgi
Tue Jan 24 23:09:37 2006 UTC (13 years, 9 months ago) by overbeek
Changes since 1.2: +10 -1 lines
queue similarities on an update_nr_cycle
Tue Jan 24 22:08:46 2006 UTC (13 years, 9 months ago) by overbeek
update aliases on an update_nr_cycle
Tue Jan 24 20:49:22 2006 UTC (13 years, 9 months ago) by overbeek
add update_nr_cycle [not debugged yet]
