[Bio] / FigKernelScripts / update_lineage.pl Repository:
Log of /FigKernelScripts/update_lineage.pl
Fri Dec 21 21:23:09 2007 UTC (12 years, 5 months ago) by wilke
Changes since 1.2: +187 -21 lines
draft version to update FIG taxonomy entries
Thu Dec 6 16:50:46 2007 UTC (12 years, 5 months ago) by wilke
Changes since 1.1: +23 -8 lines
Thu Dec 6 15:47:39 2007 UTC (12 years, 5 months ago) by wilke
Diff to selected 1.2
Updating the content of the TAXONOMY file in the organism dir and  in the  database
