[Bio] / FigKernelScripts / update_kegg_data.pl Repository:
Log of /FigKernelScripts/update_kegg_data.pl
Mon Feb 1 20:07:37 2010 UTC (10 years ago) by dejongh
CVS Tags: HEAD, mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, myrast_rel40, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
Changes since 1.5: +0 -1 lines
removed comment
Fri Oct 30 18:43:44 2009 UTC (10 years, 3 months ago) by dejongh
CVS Tags: rast_rel_2010_0118
Changes since 1.4: +15 -5 lines
warnings about non-standard shapes
Fri Oct 30 18:14:28 2009 UTC (10 years, 3 months ago) by dejongh
Remove comment on loading relational database
Fri Oct 30 17:57:32 2009 UTC (10 years, 3 months ago) by dejongh
add the rn_map.tab and the ec_map.tab
Fri Oct 30 17:48:31 2009 UTC (10 years, 3 months ago) by chenry
Changes since 1.1: +62 -46 lines
Mon Jul 13 21:02:13 2009 UTC (10 years, 7 months ago) by dejongh
CVS Tags: rast_rel_2009_0925
script to update kegg data from mirror
