[Bio] / FigKernelScripts / update_OTUs.pl Repository:
Log of /FigKernelScripts/update_OTUs.pl
Tue Feb 22 20:31:10 2011 UTC (9 years ago) by overbeek
CVS Tags: HEAD, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, myrast_rel40, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
Changes since 1.4: +91 -229 lines
fix OTU update to use gary olsen sequence grouping script
Wed Jul 21 16:51:16 2010 UTC (9 years, 7 months ago) by olson
CVS Tags: mgrast_dev_02212011, mgrast_dev_02222011, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119
Changes since 1.3: +5 -2 lines
Fix cp bug when verbose not set; close generated fasta and run formatdb when finished.
Mon Mar 29 19:50:16 2010 UTC (9 years, 11 months ago) by gdpusch
CVS Tags: rast_rel_2010_0526
Fixed pattern to recognize several variations on "16S ribosomal RNA."
Fri Mar 26 20:24:28 2010 UTC (9 years, 11 months ago) by overbeek
leave order of memebers in old OTU the same
Wed Dec 2 21:20:15 2009 UTC (10 years, 2 months ago) by gdpusch
CVS Tags: rast_rel_2010_0118
Initial checkin of script to add new genomes to OTUs, and remove deleted genomes.
