[Bio] / FigKernelScripts / trim_sequences.pl Repository:
Log of /FigKernelScripts/trim_sequences.pl
Sat Sep 12 15:43:30 2009 UTC (10 years, 2 months ago) by overbeek
CVS Tags: HEAD, mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, myrast_rel40, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
Changes since 1.10: +3 -4 lines
fixes bug in handling multidomain prots
Sun Aug 30 14:34:32 2009 UTC (10 years, 2 months ago) by overbeek
Changes since 1.9: +13 -1 lines
a hack
Thu Aug 27 12:07:55 2009 UTC (10 years, 2 months ago) by overbeek
Changes since 1.8: +38 -95 lines
rewritten
Wed Aug 26 18:59:14 2009 UTC (10 years, 2 months ago) by overbeek
fixes to ordering and max number seq
Wed Aug 26 00:44:45 2009 UTC (10 years, 2 months ago) by overbeek
Changes since 1.6: +74 -40 lines
support padding trimmed sequences
Mon Dec 5 18:56:38 2005 UTC (13 years, 11 months ago) by olson
CVS Tags: caBIG-05Apr06-00, caBIG-13Feb06-00, mgrast_rel_2008_0625, mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, rast_2008_0924, rast_rel_2008_04_23, rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_release_2008_09_29
Thu Apr 14 11:45:18 2005 UTC (14 years, 7 months ago) by overbeek
Changes since 1.4: +0 -2 lines
use neighbor joining, not fitch, to build trees
Tue Apr 12 21:25:21 2005 UTC (14 years, 7 months ago) by overbeek
fixes to trim_sequences and make_phob_from_seqs
Sat Apr 2 11:56:12 2005 UTC (14 years, 7 months ago) by overbeek
Changes since 1.2: +49 -24 lines
add update_subsys_conflicts to fig.pl
Thu Mar 31 12:31:54 2005 UTC (14 years, 7 months ago) by overbeek
add trimming to make_pu_from_seqs
Thu Mar 31 12:13:26 2005 UTC (14 years, 7 months ago) by overbeek
add trim_sequences
