[Bio] / FigKernelScripts / trim_alignment.pl Repository:
Log of /FigKernelScripts/trim_alignment.pl
Tue Jun 26 15:20:16 2007 UTC (12 years, 7 months ago) by overbeek
Changes since 1.1: +8 -1 lines
minor fixes
Sat May 12 20:12:56 2007 UTC (12 years, 9 months ago) by overbeek
add utilities for computing alignments
