[Bio] / FigKernelScripts / to_prodom.pl Repository:
Log of /FigKernelScripts/to_prodom.pl
Thu Aug 27 21:08:37 2009 UTC (10 years, 4 months ago) by olson
CVS Tags: HEAD, mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, myrast_rel40, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
Changes since 1.6: +8 -3 lines
fix updated URL
Fri Sep 8 18:59:21 2006 UTC (13 years, 4 months ago) by hwang
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, rast_2008_0924, rast_rel_2008_04_23, rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_release_2008_09_29
Change url for prodom's post
Tue Jun 6 20:07:18 2006 UTC (13 years, 7 months ago) by hwang
Changes since 1.4: +3 -1 lines
Pointed a prodom picture to the correct link
Tue Jun 6 15:14:26 2006 UTC (13 years, 7 months ago) by hwang
Changes since 1.3: +16 -5 lines
Need to get rid of the doctype and html header or it would interfere with the fig headers
Tue Jun 6 03:36:10 2006 UTC (13 years, 7 months ago) by hwang
Changes since 1.2: +1 -2 lines
uncomment out the processing seqs by prodom
Tue Jun 6 03:10:49 2006 UTC (13 years, 7 months ago) by hwang
Changes since 1.1: +37 -11 lines
protein.cgi calls this script to retrieve the output of get/post
A regular array should be passed in
Removed relative links to css so that the fig header doesn't break
Thu Jun 1 16:11:26 2006 UTC (13 years, 7 months ago) by hwang
Diff to selected 1.4
This script get/post to the ProDom website
