[Bio] / FigKernelScripts / to_org_specific.pl Repository:
Log of /FigKernelScripts/to_org_specific.pl
Mon Jul 24 18:30:22 2006 UTC (13 years, 3 months ago) by hwang
fix syntax error
Mon Jul 24 18:25:35 2006 UTC (13 years, 3 months ago) by hwang
Fixed ids (aliases) to be cleaned correctly
Wed Jul 12 20:25:42 2006 UTC (13 years, 4 months ago) by hwang
Fix a parsing error
Wed Jul 12 18:10:57 2006 UTC (13 years, 4 months ago) by hwang
LinksToTools points to this script to access other websites. The script also makes the relative links be
absolute links.
