[Bio] / FigKernelScripts / to_genbank.pl Repository:
Log of /FigKernelScripts/to_genbank.pl
Fri Sep 10 19:46:55 2010 UTC (9 years, 5 months ago) by gdpusch
CVS Tags: HEAD, mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, myrast_rel40, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
Fixed bug handling 5S.
Thu May 21 10:11:49 2009 UTC (10 years, 9 months ago) by gdpusch
CVS Tags: rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827
Changes since 1.5: +5 -1 lines
Added FIGV support.
Thu Nov 13 00:20:40 2008 UTC (11 years, 3 months ago) by gdpusch
CVS Tags: rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26
Changes since 1.4: +61 -86 lines
Updated the RNA support to match current SEED and GenBank conventions.
Wed Oct 10 20:41:34 2007 UTC (12 years, 4 months ago) by gdpusch
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, rast_2008_0924, rast_rel_2008_04_23, rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_release_2008_09_29
Changes since 1.3: +4 -1 lines
Added support for multiple contig files. -- /gdp
Thu Dec 29 01:11:30 2005 UTC (14 years, 1 month ago) by overbeek
Fixed sorting bug. -- /gdp
Sat Dec 24 18:47:03 2005 UTC (14 years, 1 month ago) by overbeek
Changes since 1.1: +24 -4 lines
Added missing field, plus strain support. -- /gdp
Sat Dec 24 18:05:39 2005 UTC (14 years, 1 month ago) by overbeek
Initial draft of GenBank output routine. -- /gdp
