[Bio] / FigKernelScripts / tips_of.pl Repository:
Log of /FigKernelScripts/tips_of.pl
Tue Dec 19 21:07:16 2006 UTC (12 years, 11 months ago) by overbeek
Changes since 1.2: +0 -44 lines
add insert_prot_into_tree, a new way to insert proteins into a tree
Mon Dec 5 18:56:38 2005 UTC (13 years, 11 months ago) by olson
Thu Dec 30 02:30:16 2004 UTC (14 years, 10 months ago) by overbeek
add tree manipulation utilities
