[Bio] / FigKernelScripts / test_parse_gff.pl Repository:
Log of /FigKernelScripts/test_parse_gff.pl
Wed Dec 7 19:38:22 2005 UTC (14 years, 2 months ago) by golsen
Don't mean to be pedantic, but I figured that I might as well add newlines
at the end of text files that lack one.  Identified with a script:
/bin/sh -O extglob -c 'for f in */*.@(c|css|html|js|pl|pm|py|TXT); do perl -e '"'"'while(<>) {$s = ! /\n$/} exit $s'"'"' $f || echo $f; done'
fixed with a script:
/bin/sh
for file in _list_; do echo "" >> $file; done
Mon Dec 5 18:56:38 2005 UTC (14 years, 2 months ago) by olson
Tue Mar 15 19:46:51 2005 UTC (14 years, 11 months ago) by olson
GFF parsing/generation test scripts.
