[Bio] / FigKernelScripts / test_figfam_peg.pl Repository:
Log of /FigKernelScripts/test_figfam_peg.pl
Wed Jun 18 15:38:14 2008 UTC (12 years ago) by arodri7
CVS Tags: HEAD, mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_rel_2008_0625, mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, myrast_rel40, rast_2008_0924, rast_rel_2008_07_21, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912, rast_release_2008_09_29
Changes since 1.5: +11 -1 lines
update changes
Thu Apr 17 20:48:15 2008 UTC (12 years, 2 months ago) by olson
Introduct &FIG::get_figfams_data()
Fri Apr 11 12:00:34 2008 UTC (12 years, 2 months ago) by overbeek
Changes since 1.3: +3 -3 lines
updates to FIGfam quality control
Sat Mar 1 15:52:45 2008 UTC (12 years, 4 months ago) by overbeek
changes from ::data/FigfamsData to ::FigfamsData
Sat Oct 13 15:10:06 2007 UTC (12 years, 8 months ago) by overbeek
Changes since 1.1: +10 -1 lines
fixes to fc_figfams
Sat Apr 28 14:47:53 2007 UTC (13 years, 2 months ago) by overbeek
Diff to selected 1.3
add best_tree_using_proml_on_cluster
