[Bio] / FigKernelScripts / test_cv.pl Repository:
Log of /FigKernelScripts/test_cv.pl
Mon Dec 5 18:56:38 2005 UTC (14 years, 1 month ago) by olson
Thu Nov 10 19:57:41 2005 UTC (14 years, 2 months ago) by efrank
CVS Tags: caBIG-00-00-00
Diff to selected 1.2
Basic regression test on CV stuff at FIG API level (which underlies CGI).
