[Bio] / FigKernelScripts / synchronize_annotations_and_assignments.pl Repository:
Log of /FigKernelScripts/synchronize_annotations_and_assignments.pl
Mon Dec 5 18:56:38 2005 UTC (14 years, 6 months ago) by olson
Fri Sep 2 16:26:48 2005 UTC (14 years, 9 months ago) by olson
Generate an annotation file and an assignment file that when installed
will bring the  annotations and assignments back into synch.
