[Bio] / FigKernelScripts / synchronize_annotations_and_assignments.pl Repository:
Log of /FigKernelScripts/synchronize_annotations_and_assignments.pl
Links to mgrast_release_3_0_1: (view) (download) (as text) (annotate)
Mon Dec 5 18:56:38 2005 UTC (14 years, 6 months ago) by olson
Fri Sep 2 16:26:48 2005 UTC (14 years, 10 months ago) by olson
Diff to selected 1.2
Generate an annotation file and an assignment file that when installed
will bring the  annotations and assignments back into synch.
