[Bio] / FigKernelScripts / synchronize_annotations_and_assignments.pl Repository:
Log of /FigKernelScripts/synchronize_annotations_and_assignments.pl
Mon Dec 5 18:56:38 2005 UTC (14 years, 7 months ago) by olson
Fri Sep 2 16:26:48 2005 UTC (14 years, 10 months ago) by olson
Diff to selected 1.2
Generate an annotation file and an assignment file that when installed
will bring the  annotations and assignments back into synch.
