[Bio] / FigKernelScripts / svr_update_assignments.pl Repository:
Log of /FigKernelScripts/svr_update_assignments.pl
Tue Jan 19 18:14:49 2010 UTC (10 years, 1 month ago) by gdpusch
Fixed typo.
Tue Jan 19 18:07:20 2010 UTC (10 years, 1 month ago) by gdpusch
Changes since 1.1: +2 -32 lines
Fixed usage msg, stripped off tool_hdr.
Tue Jan 19 18:03:15 2010 UTC (10 years, 1 month ago) by gdpusch
Initial checkin.
