[Bio] / FigKernelScripts / svr_trim_ali.pl Repository:
Log of /FigKernelScripts/svr_trim_ali.pl
Thu Feb 24 21:54:12 2011 UTC (9 years, 1 month ago) by fangfang
CVS Tags: HEAD, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, myrast_rel40, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
Changes since 1.9: +4 -4 lines
fix description field in trim html
Thu Feb 24 21:50:50 2011 UTC (9 years, 1 month ago) by fangfang
fix bug in showing html with trimmed ends
Mon Dec 27 00:07:33 2010 UTC (9 years, 3 months ago) by fangfang
CVS Tags: mgrast_dev_02212011, mgrast_dev_02222011, rast_rel_2011_0119
Changes since 1.7: +70 -13 lines
new algorithm for trimming to conserved domains
Mon Nov 29 19:50:16 2010 UTC (9 years, 4 months ago) by fangfang
CVS Tags: rast_rel_2010_1206
Changes since 1.6: +2 -2 lines
update options
Sun Nov 14 20:51:41 2010 UTC (9 years, 4 months ago) by fangfang
fixed typo
Thu Nov 11 07:40:04 2010 UTC (9 years, 4 months ago) by fangfang
Changes since 1.4: +37 -14 lines
updates
Wed Nov 10 17:32:14 2010 UTC (9 years, 4 months ago) by fangfang
Changes since 1.3: +23 -21 lines
add -auto option if mafft is chosen
Wed Nov 10 16:56:31 2010 UTC (9 years, 4 months ago) by fangfang
Changes since 1.2: +137 -15 lines
Update: runs remotely by default
Thu Oct 28 13:13:54 2010 UTC (9 years, 5 months ago) by fangfang
Changes since 1.1: +0 -1 lines
remove dependency
Wed Oct 27 20:04:44 2010 UTC (9 years, 5 months ago) by fangfang
svr script for trimming alignments
