[Bio] / FigKernelScripts / svr_translations_of.pl Repository:
Log of /FigKernelScripts/svr_translations_of.pl
Tue Feb 8 21:38:19 2011 UTC (8 years, 9 months ago) by golsen
CVS Tags: HEAD, mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, myrast_rel40, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
Changes since 1.5: +101 -19 lines
Add an option of genome names in the output.
Clean up the way functions are added.
Add POD.
Mon Jan 24 02:04:33 2011 UTC (8 years, 9 months ago) by golsen
Changes since 1.4: +54 -13 lines
Add flag for including the assigned function (-function or -a).
Add short flag for fasta format (-f).
Thu Dec 17 20:24:56 2009 UTC (9 years, 11 months ago) by parrello
CVS Tags: rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119
Changes since 1.3: +20 -21 lines
Fixed to work with no input.
Wed Dec 16 17:11:16 2009 UTC (9 years, 11 months ago) by parrello
Changes since 1.2: +9 -9 lines
Fixed.
Fri Dec 11 22:04:09 2009 UTC (9 years, 11 months ago) by olson
add sas declaration
Sat Nov 7 16:56:45 2009 UTC (10 years ago) by overbeek
server scripts for basic utilities
