[Bio] / FigKernelScripts / svr_submit_RAST_job.pl Repository:
Log of /FigKernelScripts/svr_submit_RAST_job.pl
Fri Jun 3 21:57:07 2016 UTC (3 years, 5 months ago) by olson
CVS Tags: HEAD
Changes since 1.16: +4 -1 lines
Diff to previous 1.16
Add rasttk submission support
Fri Jun 3 20:04:31 2016 UTC (3 years, 5 months ago) by olson
Changes since 1.15: +5 -0 lines
add fix_frameshifts argument
Wed Feb 29 19:13:31 2012 UTC (7 years, 8 months ago) by olson
CVS Tags: mgrast_version_3_2, rast_rel_2014_0729, rast_rel_2014_0912
fix typo
Wed Sep 28 20:42:00 2011 UTC (8 years, 1 month ago) by olson
CVS Tags: mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_1_2, rast_rel_2011_0928
Changes since 1.13: +8 -1 lines
Add kmerDataset selection support.
Tue Nov 23 20:08:31 2010 UTC (8 years, 11 months ago) by gdpusch
CVS Tags: mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, myrast_33, myrast_rel40, rast_rel_2010_1206, rast_rel_2011_0119
Changes since 1.12: +20 -20 lines
Added default value for bioname.
Mon Sep 20 21:38:52 2010 UTC (9 years, 1 month ago) by olson
CVS Tags: rast_rel_2010_0928
Changes since 1.11: +5 -2 lines
Add --determineFamily
Mon Jan 18 23:32:09 2010 UTC (9 years, 9 months ago) by olson
CVS Tags: rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827
Changes since 1.10: +8 -5 lines
nonActive mods
Thu Oct 29 16:20:08 2009 UTC (10 years ago) by olson
Changes since 1.9: +4 -2 lines
Fix 666666 problem.
Add support for using the test server.
Wed Oct 28 20:38:38 2009 UTC (10 years ago) by olson
Changes since 1.8: +4 -3 lines
fixups
Wed Oct 28 20:24:25 2009 UTC (10 years ago) by olson
Changes since 1.7: +2 -12 lines
Misc server fixes
Wed Oct 28 17:18:32 2009 UTC (10 years ago) by gdpusch
Fixed bug in file-check logic.
Wed Oct 28 17:09:57 2009 UTC (10 years ago) by gdpusch
Changes since 1.5: +7 -0 lines
Wed Oct 28 16:19:07 2009 UTC (10 years ago) by olson
Changes since 1.4: +5 -1 lines
Add SAS tag, remove use of FIG_Config.
Wed Oct 28 16:17:03 2009 UTC (10 years ago) by olson
Changes since 1.3: +6 -12 lines
some bugfixes
Mon Oct 26 23:09:29 2009 UTC (10 years ago) by gdpusch
Added graceful exit with usage-msg in case where script has no arguments.
Mon Oct 26 22:48:43 2009 UTC (10 years ago) by gdpusch
Changes since 1.1: +82 -31 lines
Added support for FASTA submissions.
Mon Oct 26 19:31:06 2009 UTC (10 years ago) by gdpusch
Initial check-in. -- /gdp
