[Bio] / FigKernelScripts / svr_status_of_RAST_job.pl Repository:
Log of /FigKernelScripts/svr_status_of_RAST_job.pl
Tue Jan 19 00:06:16 2010 UTC (10 years, 1 month ago) by olson
Changes since 1.3: +17 -3 lines
add url argument
Mon Oct 26 18:19:57 2009 UTC (10 years, 3 months ago) by olson
Changes since 1.2: +5 -0 lines
Add SAS comments.
Add real implementation of user_may_access_job and user_owns_job in RAST_submission
so that the batch interface obeys the permissions set up by the RAST server.
Thu Oct 22 21:15:13 2009 UTC (10 years, 3 months ago) by olson
Changes since 1.1: +18 -1 lines
Lastest code. working submissions, plus kill & delete job.
Tue Oct 20 21:23:55 2009 UTC (10 years, 3 months ago) by olson
user script for rast job status
