[Bio] / FigKernelScripts / svr_scanP.pl Repository:
Log of /FigKernelScripts/svr_scanP.pl
Mon Apr 4 13:35:04 2011 UTC (8 years, 10 months ago) by overbeek
CVS Tags: HEAD, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_rel40, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
Changes since 1.1: +8 -0 lines
add a little documentation
Sat Apr 2 17:52:07 2011 UTC (8 years, 10 months ago) by overbeek
add a wrapper for protein scan_for_matches
