[Bio] / FigKernelScripts / svr_run_RAST_jobs.pl Repository:
Log of /FigKernelScripts/svr_run_RAST_jobs.pl
Wed Sep 28 20:42:00 2011 UTC (8 years, 6 months ago) by olson
CVS Tags: HEAD, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_1_2, mgrast_version_3_2, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
Changes since 1.6: +9 -0 lines
Add kmerDataset selection support.
Mon Sep 20 21:38:53 2010 UTC (9 years, 6 months ago) by olson
CVS Tags: mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, myrast_33, myrast_rel40, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119
Changes since 1.5: +4 -1 lines
Add --determineFamily
Mon Jan 18 23:32:09 2010 UTC (10 years, 2 months ago) by olson
CVS Tags: rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827
Changes since 1.4: +18 -5 lines
nonActive mods
Thu Dec 10 19:31:12 2009 UTC (10 years, 3 months ago) by olson
Changes since 1.3: +10 -5 lines
changes for new server stuff
Tue Dec 8 02:11:31 2009 UTC (10 years, 3 months ago) by gdpusch
Changes since 1.2: +8 -2 lines
Added support for test server.
Wed Oct 28 16:50:24 2009 UTC (10 years, 5 months ago) by olson
Changes since 1.1: +23 -12 lines
Make the output look decent.
Wed Oct 28 16:32:47 2009 UTC (10 years, 5 months ago) by olson
Diff to selected 1.3
Rename.
