[Bio] / FigKernelScripts / svr_roles_to_subsys.pl Repository:
Log of /FigKernelScripts/svr_roles_to_subsys.pl
Thu Oct 21 13:02:28 2010 UTC (9 years, 4 months ago) by parrello
CVS Tags: mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, myrast_33, myrast_rel40, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928
Added "roles_to_subsys", sped up "figfams_to_ids", fixed pod for "mapped_genomes".
