[Bio] / FigKernelScripts / svr_role_to_pegs.pl Repository:
Log of /FigKernelScripts/svr_role_to_pegs.pl
Sun Mar 13 22:13:09 2011 UTC (8 years, 11 months ago) by overbeek
CVS Tags: HEAD, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, myrast_rel40, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
mispelled genome with bad consequences
Sun Mar 13 21:58:47 2011 UTC (8 years, 11 months ago) by overbeek
fix documentation - changed peg to role in many spots
Wed Dec 1 14:24:49 2010 UTC (9 years, 2 months ago) by overbeek
CVS Tags: mgrast_dev_02212011, mgrast_dev_02222011, mgrast_release_3_0, mgrast_release_3_0_1, rast_rel_2010_1206, rast_rel_2011_0119
two small utilities
