[Bio] / FigKernelScripts / svr_preferred_roles.pl Repository:
Log of /FigKernelScripts/svr_preferred_roles.pl
Mon Dec 22 16:00:47 2014 UTC (4 years, 11 months ago) by overbeek
CVS Tags: HEAD
Changes since 1.5: +23694 -6310 lines
translation fixes
Mon Dec 22 15:20:53 2014 UTC (4 years, 11 months ago) by overbeek
Changes since 1.4: +89809 -58369 lines
update on translations
Mon Dec 22 15:06:01 2014 UTC (4 years, 11 months ago) by overbeek
Changes since 1.3: +23 -21 lines
translation update
Sun Dec 21 21:45:05 2014 UTC (4 years, 11 months ago) by overbeek
Changes since 1.2: +11 -1 lines
add option of showing only diffs
Sun Dec 21 15:11:01 2014 UTC (4 years, 11 months ago) by overbeek
fix org in comment
Sun Dec 21 15:05:29 2014 UTC (4 years, 11 months ago) by overbeek
get preferred roles
